Animating particular emitter through a path or stroke...
COW Forums : Trapcode
Pharhaan
on Jun 19, 2006 at 10:53:43 pm
Hi, there,
I am confronting a trouble here, where I am a newbea and still learning After Effects so far I have learnt a lot but still to go.
My questing is,
How could I animate Trapcode's Particular on a path drawn by the pen tool in the after effects. Actually the scenario I am trying to accomplish is,
I have a title of a video promo which is been written by a pen (an image) and will move through the path like a signature style and on to its tip I want an emiiter to be placed and move around with its tip on a path and emits the particles all along.
What is the procedure to finish this task.
Kindly reply me soon
Regards,
Pharhaan Xaher
Mylenium
Re: Animating particular emitter through a path or stroke...
on Jun 20, 2006 at 6:03:54 am
Simply copy your path that you are using (a stroke mask? position keyframes in the Write-On effect?) to the emitter XY position in Particular. All you need to adjust is the timing.
Mylenium
[Pour Myl
mlebac
on Jun 30, 2006 at 1:34:22 pm
Hello.
I am not sure I understand how to acomplish the thing you suggested. I have imported a path from Illustrator, that I want to use as a path for emitter. How exactly do I copy it to XY position? Do I use options window or effect window?
Thank you for reply.
