Equlizer bars with Sound Key & Expressions
COW Forums : Trapcode
djelder
on Jun 19, 2006 at 2:47:10 pm
Hi, I've been trying to create equalizer bars with soundkeys and I've been using this expression "temp = thisComp.layer("Equalizer").effect("Sound Keys")("Output 1");
[320,240]", but I can't get it to move like an equalizer bar does, do I need to do an expression on the y-axis of scaling or what should I do to affect that relationship. Thanks.
Daniel Elder
Associate Producer
http://www.luminair.com
djelder
For anyone who wants to make Equalizer Bars w/ Sound Keys
on Jun 19, 2006 at 3:16:49 pm
I have found a way to make it with Expressions and Just standard anchor points.
1. I found the music I needed and went through the sound key process.
2. I added an expression to Scale "temp = thisComp.layer("Expressions").effect("Sound Keys")("Output 1");
[100, temp]"
3. I changed the anchorpoint to 360, 480 to set up the position Expression
4. I added an expression to position "temp = thisComp.layer("Expressions").effect("Sound Keys")("Output 1");
[320, 480]"
That should take care of making equalizer bars for those of you who want that sort of effect with your music. Now I think I will add a shine adjustment layer to it all to jazz it up a bit.
D-
Daniel Elder
Associate Producer
