trapcode particular emitter motion paths
COW Forums : Trapcode
dominiclincoln
on Jun 7, 2006 at 12:28:24 pm
Hello. Yesterday I was tracking a particle emitter to the bottom of a rocket in after effects with trapcode particular. Quite by accident I managed to make the path of the emitter to display in the composition window as a regular motion path. I was merrily adjusting the bezier handles on each keyframe for a smooth curve with no problem but today I can't seem to make the path appear as it did before. All i get is the emitter position and thats it, no keyframes, no nothing. Has anyone else found this and is there a way to make the path appear again. Of course its possible to make a light or layer act as an emitter, but this way was so much easier. Any ideas as to why I can't make the path appear? Thanks.
Mylenium
Re: trapcode particular emitter motion paths
on Jun 7, 2006 at 4:17:32 pm
You have opened the layer viewer by double clicking on the layer, not the composition window, I presume.
Mylenium
[Pour Myl
dominiclincoln
on Jun 7, 2006 at 5:00:09 pm
And just like, that, my problems are solved. thanks a million. My quest is over.
