dissolving text
COW Forums : Trapcode
donnii
dissolving text
on May 21, 2006 at 4:50:16 pm
hi,
i know this question is often asked but by now i didn`t find an answer...
I
Peder Norrby
Re: dissolving text
on May 21, 2006 at 10:08:28 pm
Check this out:
http://www.trapcode-people.net/filedetails.php?fileid=107
Peder Norrby / Trapcode
donnii
Re: dissolving text
on May 21, 2006 at 11:26:47 pm
okay...thanks a lot, actually simple ;))
BUT...in this case it's "easy" because all particles appear at the same time, so the opacitiy of the text precomp
can change to 0% over 1 frame...But what do you do if you want to let the particles emitting over 4sec ? The text layer should
disappear particle by particle.
Mylenium
Re: dissolving text
on May 22, 2006 at 6:00:12 am
Use Clip --> Stretch for your custom particles and animate the Life parameter for the particles. May take some tweaking, since there is some overlap as the age is sampled dynamically, but eventually you'll get there.
Mylenium
[Pour Myl
Peder Norrby
Re: dissolving text
on May 22, 2006 at 9:25:27 am
OK, how about this one:
http://www.trapcode-people.net/filedetails.php?fileid=108
