particular
COW Forums : Trapcode
jealondon
particular
on May 3, 2006 at 1:55:55 am
hi,
i am college student , and new to adobe after effects and trapcoade, part of my project i am creating small logo and i have basic idea. http://www.icanhardlywait.net/symbolic/world-map-test.mov i am thinking to creat something like that,
i did tutorial from trapcode website http://www.trapcode.com/in_action/particular_bounce.html
i have try this but not work , for example i have some text on layer i need particular fly and stick on the only text and cant make invisible layer.
many thanx
jea
Mylenium
Re: particular
on May 3, 2006 at 9:14:28 am
Wrong approach. That world map example could for instance be done with Card Dance and gradient layers driving it, as could most likely be your text. If you wanted to stick with Particular, your best bet would be using a layer grid emitter with a custom square shaped particle, all in a sub-comp, and then you time-reverse the sub-comp as a layer in your main comp. However, you will never get the squares to align 100% exact, so you'd still have to cheat by adding a crossfade and blend it with the "real" text.
Mylenium
[Pour Myl
