Rotating a camera entirely around a frozen particular system
COW Forums : Trapcode
xfuzion
on Apr 19, 2006 at 9:59:12 am
Basically I've frozen particals and have a camera on a circle motion path 360 degrees around the composition and it seems to chop from 180->181 degrees and also it has a "zoom in " distortion at the corners.
Is there any fixing this in after effects?
Peder Norrby
Re: Rotating a camera entirely around a frozen particular system
on Apr 19, 2006 at 3:04:18 pm
Not sure what you mean by a zoom-in distortion, is the lens too wide maybe? Adjust in camera settings.
The easiest way to make a 360 spin around a center point is to create a null, switch to 3D, parent camera to null. Set keyframes for Y rotation on the null.
Peder Norrby / Trapcode
YAMIR bhatt
on Apr 28, 2006 at 1:37:40 pm
firstly how do you freez the particle? i was hoping there should be a way? are you using AE's 3d camera or animating the emiter in particular? ican you eleborate a little more please.
