Pasting output keyframes to time-remap layer. . .
COW Forums : Trapcode
Arie Stavchansky
on Apr 17, 2006 at 5:11:33 pm
Hi There,
In SoundKeys, after I generate the output keyframes for my first Range, I copy them, but when I paste them into the Time-Remap layer they keep the image still. What are the appropriate settings soundkeys so that it can work with time remapping. Do I have to use a different "Type" paramter and a different "fall off"?
Arie
Mylenium
Re: Pasting output keyframes to time-remap layer. . .
on Apr 18, 2006 at 4:55:36 am
Time Remap uses - errm - time, which Soundkeys doesn't output directly, no matter what settings you use. Here's what you should do:
a) Make the custom range in Soundkeys equal the length of your composition/ layer in frames (e.g. 0-500)
b) Apply an expression to the target parameter such as
framesToTime(thisComp.layer("Soundkeys").effect("Soundkeys")("Output 1"))
Mylenium
[Pour Myl
cowcowcowcowcow
holbylarsen
on Apr 20, 2006 at 10:44:22 am
whatever happened to that great example called "rythmfly", it used to be on trapcodes page
that was a really nice example of what soundkeys could do with time remapping, complete with a script.
if anyone still has that, that should be the answer to this, no?
