Pausing the Action in Particular.
COW Forums : Trapcode
Stryker187
on Apr 14, 2006 at 5:13:23 am
I need some help. I seen a tutorial before I think on this site, that explained how to stop time in particular so you could move around an object with the camera or whatever. Anyone know how to do this. Thanks, it has been driving me nuts. Also having issues getting particles to rotate. Doing Any explosion effect have a short burst of particles and want to add some Y spin, but i key frame it and it doesnt move. Thanks
Stryker187
Mylenium
Re: Pausing the Action in Particular.
on Apr 14, 2006 at 9:26:12 am
You can stop the particles using the physics time factor. Particles will always be aligned to face the camera, they only rotate around their local Z axis. If you need other rotation, animate them in a sub-comp and use the collapse transformations/continuously rasterize switch.
Mylenium
[Pour Myl
Peder Norrby
on Apr 16, 2006 at 1:07:12 pm
I do not recomend using collapse transformations on the particle layer, it makes it really slow and does not render the correct persective anyway.
Peder Norrby / Trapcode
