Creating a fuse with 3D stroke and particular
COW Forums : Trapcode
PlayingKarrde
on Apr 13, 2006 at 5:47:43 pm
I'm looking to create a 3d fuse with 3d stroke and particular but not sure where to start. Could someone point me in the right direction (basically having the emitter snapped to the end of the 3D stroke).
Thanks in advance.
Peder Norrby
Re: Creating a fuse with 3D stroke and particular
on Apr 13, 2006 at 6:31:25 pm
Use a square pixel comp.
Start with the 3D Stroke, create your fuse.
Then, in the timeline, select the Mask Shape property and hit copy.
Create particular layer, and
In the timeline, select the Emitter>Position XY property and hit paste.
Peder Norrby / Trapcode
PlayingKarrde
on Apr 13, 2006 at 6:40:43 pm
Unbelievable. So easy.
Thank you so much (and thanks for the best plugin suite I've used).
