Fireworks...
COW Forums : Trapcode
MissyMoments
Fireworks...
on Apr 6, 2006 at 11:08:25 pm
I'm trying to create a fireworks show using Trapcode particular. Any suggestions about how to go about doing this? Everytime I use more than one "firework" you can't see it.
Missy Moments
Mylenium
Re: Fireworks...
on Apr 7, 2006 at 6:04:35 am
Particular allows only one instance of it per layer - each Particular completely overwrites the effect of the previous instance. You need to use multiple layers.
Mylenium
[Pour Myl
cowcowcowcow
MissyMoments
Re: Fireworks...
on Apr 7, 2006 at 2:38:06 pm
Thank you. And is it possible to have a firework "blast"...fade... then "blast" again? If so, what setting do I adjust?
Missy Moments
Mylenium
Re: Fireworks...
on Apr 8, 2006 at 7:30:09 pm
You can animate the emitter rate to get multiple shots of fireworks. By creating additional keys e.g. for particle color you can have different styles even with just a single instance of Particular. In case you haven't, I suggest you download the PyroPack for Particular from the Trapcode website. It illustrates most of those things and conatins some very nice fireworks presets.
Mylenium
[Pour Myl
