Sound Key Parameters
COW Forums : Trapcode
ChrisJames
on Mar 31, 2006 at 12:27:57 am
Hi Guys, Im wondering if anyone could help me with something. Im using soundkeys for a project at the moment but cant seem to figure out how to set certain parameters to how the plugin effects my layers. For instance if i have a layer that scales to a kick drum how to set how much it can scale by or say if only height scales and not the width? Any help would be brilliant:)
Chris
Mylenium
Re: Sound Key Parameters
on Mar 31, 2006 at 5:53:24 am
You need to use expressions. Scale is an array that stores two values. To separate them, use something similar to this:
my_volume=thisComp.layer("Soundkeys").effect("Soundkeys")("Output 1");
X=scale[0];
Y=my_volume;
[X,Y]
Mylenium
[Pour Myl
ChrisJames
on Mar 31, 2006 at 8:18:23 am
Ah thanks man, Im new to expressions so Im a little confused to where I add my values. Say for instance I wanted a layer to scale in height between 20pixels to 250 pixels.
Thanks again man
Mylenium
on Mar 31, 2006 at 9:01:22 am
Scale is a proportional parameter expressed in percend. You would need to add some extra expression code to make it conform to pixel values.
min_val=20;
max_val=250;
X=scale[0];
Y=linear(my_volume,0,100,min_val,max_val);
[X,Y]
Mylenium
[Pour Myl
Mylenium
on Mar 31, 2006 at 9:10:15 am
Ooops, values need to be just the other way around;
min_val=20;
max_val=250;
X=scale[0];
Y=linear(my_volume,min_val,max_val,0,100);
[X,Y]
Mylenium
[Pour Myl
William Hamilton
on Apr 9, 2009 at 8:40:27 pm
I tried this expression you posted and get errors.
Here is the expression I get when I attach the scale picwhip to Output 1 in Sound Keys:
temp = thisComp.layer("Soundkeys").effect("Sound Keys")("Output 1");
[temp, temp]
What do I add to this expression to control how much I want my object to scale?
