Dotted Line in 3D Stroke?
COW Forums : Trapcode
Adam Duguay
on Mar 26, 2006 at 8:51:01 pm
How to I get a dotted line with 3D stroke?
Can anyone help?
A
gcole_5
Re: Dotted Line in 3D Stroke?
on Mar 29, 2006 at 7:47:16 am
Only way I can think to do it is to animate a single instance/layer with 3D Stroke using a very small gap between Start and End values (Start=1 and End=2 - this will give you a dot or dash) -- animate the offset value. Then, duplicate the layer and change the Start and End to Start=3 and End=4 in the duplicate layer...repeat this for every dash, increasing the Start and End values for each new duplicated layer.
Not very elegant, but it will get you a dotted line.
An easier way to achieve the duplicated layers is to apply Trapcode Echospace to the initial layer and then enter say 50 for instances and .02 for the layer delay.
Greg
gcole_5
on Mar 29, 2006 at 8:06:50 am
I should have mentioned this, too... If all you are trying to get is a dotted line (rather than dashed), play with the 'Adjust Step' value under the Advanced tab. Setting this to 1000+ and tweaking your stroke Feather and Thickness can give you nice dotted lines.
