SWARM... SWARM
COW Forums : Trapcode
HansGruber
SWARM... SWARM
on Mar 24, 2006 at 9:01:20 pm
Hey,
Does anyone know how to create this type of realistic swarm.
http://images.templatemonster.com/screenshots/9100/9183.html
(the part when it flies past the glass ball)
I'm using trapcodes particular, but I will try anything. HELP!!!
--Paul
gcole_5
Re: SWARM... SWARM
on Mar 24, 2006 at 11:22:13 pm
Not sure about the reflective look on the 'sphere' (could be spherize? or lens warp? -- other similar warp filter), but to make the particles appear as though they move around it, place a spherical influence (under physics>air) in your 3D scene and the particles will flow around it as they pass.
Greg
gcole_5
Re: SWARM... SWARM - file example
on Mar 24, 2006 at 11:58:26 pm
Here is a 15 minute example file to give you an idea where to start. I started with the flies swarm preset, added a spherical influence placed away from the camera, moved the particles 'through' the sphere causing them to warp around it - then added a masked adjustment layer with CC lens over the position of the spherical influence... I'm sure you could make it look a lot nicer with some additional tweaks, but this should get you going.
File: http://www.espermedia.com/ae_share/swarm_sphere.aep
Greg
Mylenium
Re: SWARM... SWARM
on Mar 25, 2006 at 3:11:29 pm
What a distasteful intro... Anyway, what gcole said is more than usable. I'd try to add up a little on the Air Resistance to make it look a bit more viscous.
Mylenium
[Pour Myl
HansGruber
Re: SWARM... SWARM
on Mar 27, 2006 at 3:43:52 pm
Ok thanks guys.
Ill give it a shot.
