Trapcode/ Nucleo issues
COW Forums : Trapcode
Scott Frizzle
on Mar 16, 2006 at 3:13:18 pm
When I render animations that use Shine or Particular with Nucleo, I'm getting random frames that have the red "unregistered" X drawn through them. This is the Trapcode unregistered message, not the Nucleo one. I am quite sure that the Trapcode plugs were working fine Just a week or so ago, but now I have to shut off Nucleo to render when using Trapcode.
Any ideas?
I'm on a Mac Quad G5 running AE 7 with the patest version of Nucleo.
Scott Frizzle
Re: Trapcode/ Nucleo issues- fixed
on Mar 16, 2006 at 4:15:27 pm
In case anyone else runs into this problem, here's a fix provided by Gridiron Software that seems to do the trick:
"For the Trapcode problem we had another using with a similar issue and he needed to re-enter his Trapcode license while Nucleo was active and then disable and re-enable Nucleo. To disable Nucleo click (right-click on Windows) and select Disable from the drop-down menu. Click on the icon again and select Enable to re-enable Nucleo."
