Smoking Text
COW Forums : Trapcode
adrianno
Smoking Text
on Feb 12, 2006 at 3:40:32 am
I would like to create a Text taht turns into smoke. While turning into Smoke, this Text should get invisible <- because it turns into smoke. Is it possible to creat this effect with particular?
Mylenium
Re: Smoking Text
on Feb 12, 2006 at 5:27:17 pm
[adrianno] "Hi,
I would like to create a Text taht turns into smoke. While turning into Smoke, this Text should get invisible <- because it turns into smoke. Is it possible to creat this effect with particular?"
Anything is possible with the right approach, but your post sounds like you're expecting Particular to do all the work for you... Anyway, not too difficult. Put your text in a sub-comp and animate the dissolve whichever way you like, then use that comp as an layer emitter for Particular in another composition.
Mylenium
[Pour Myl
Charles Bittner
Re: Smoking Text
on Feb 16, 2006 at 1:32:12 am
yep just what mylenium said....
Mylenium nice job on the graph demo, man you made the complex not so...
