flight through the clouds
COW Forums : Trapcode
bembler
on Feb 6, 2006 at 10:50:16 pm
hi together
I tried to work with "cloudflight"
What I want is to go through the sky and to see downwards on the earth. So I put an image of germany behind the cloudflight. I moved the camera- but that doesn't work.
It is just the first time I tried to use particular but how could I manage this problem ?
Greetings from munich
Thea
Mylenium
Re: flight through the clouds
on Feb 7, 2006 at 5:44:01 am
I have no idea what you are talking about... Could you be more specific?
Gr
bembler
on Feb 7, 2006 at 7:43:44 am
hi,
it's "cloudflight.aep" on
http://www.trapcode.com/info_cloudflight.html
Mylenium
on Feb 7, 2006 at 10:27:37 am
Yeah, I knew that. I was more refering to how you were integrating the image and how you move your camera. Cloudflight itself is more or less a static emitter that only compensates for camera banking, so it might require some changes to get it to work for your project.
Mylenium
[Pour Myl
