Looking to crate a cone w/3D stroke.
COW Forums : Trapcode
JeremyG
on Feb 3, 2006 at 6:20:12 pm
Hello, I am looking to create a cone shaped stoke (think tornado). Is this possible with 3D stroke? I can make a kick butt spring, but can't seem to get a cone.
Thanks for any insight.
Jeremy
Mylenium
Re: Looking to crate a cone w/3D stroke.
on Feb 4, 2006 at 9:39:08 am
There's a million ways to do this, but I'm not sure how you'r approaching the problam. Wghat I'd do is draw out the funnels cross section and then use the repeater. O were you trying to use Taper?.
Mylenium
[Pour Myl
JeremyG
on Feb 4, 2006 at 9:55:26 am
Thanks for the response.
Yep, trying to taper. I tried drawing a spiral in illustrator, but couldn't quite figure out how to stretch it down into a funnel shape.
A cross section and repeater sounds interesting, but as you point out the taper would be funky.
Any other ideas?
Jean-Nicolas Duval
on Nov 28, 2008 at 3:23:37 pm
Hi Jeremy,
I know this post is getting quite old, but I need to take my chance.
I was Wondering if you'd finally come up with a solution on doing a tornado shape that uses the taper function in trapcode 3d stroke.
Any response would be greatly appreciated.
