3d stroke and Motion Tracking
COW Forums : Trapcode
Jack Black
on Jan 20, 2006 at 9:31:42 pm
I have setup a short 6sec clip where I have motion tracked my finger, I want to use the data to make it like there is a streak or tail following my finger, but how do I apply the data to the stroke? I have setup a solid the size of the comp and applied 3d stroke, but that's as far as I got, if I apply the data to the solid layer it just applies the key frames to the transform-position value instead of to a mask or something?
dom_EESB
Re: 3d stroke and Motion Tracking
on Jan 26, 2006 at 12:29:24 am
Instead of using 3D stroke, use particular, set an emitter to leave particles which don't disperse, and last a long time - and so resemble a 3D stroke effect. Then all you need to do is apply the tracker position to the emitter of the particles.
Dominic Osborne
Director & Head of Visuals
Eight Eyed Sea Bass Ltd
http://www.eighteyedseabass.com
