Problem installing Particular
COW Forums : Trapcode
GotFlow
on Dec 29, 2005 at 8:30:58 am
Hi! I work with the german version of Adobe After Effects 6.5. My problem is: I can't see the plugin in AE although directory and everything is correct. The aex-files of the plugins are in the plugin-folder.
What is the problem?
It's the demo version.
Greetings
Flo
Mylenium
Re: Problem installing Particular
on Dec 29, 2005 at 3:45:37 pm
what OS are you using? In case you use Win2K or XP make sure you have proper user permissions and file attributes set. You may also want to set your folder options to show system and hidden files. For unexplained resons this also affects AE's ability to scan for plugins.
Mylenium
[Pour Myl
