Trapcode Particle effect to swf?
COW Forums : Trapcode
Rickfourt
on Dec 23, 2005 at 1:35:53 am
Hello i just wonder if there is a way to export an animation i did using the snownight1 particular effect to flash format swf.
when i try i only get a black box. although i see it snowing in Adobe After Effects so its working in there.
is it possible or do i have to make the animation an flv file and then get it from flash that way?
/Rick
Learning
Peder Norrby
Re: Trapcode Particle effect to swf?
on Dec 23, 2005 at 3:59:27 pm
Hello,
I don't know much about flash, but in this respect, regarding outputting to flash, Trapcode Particular works like any other effect in AE so you can turn to Adobe support or try the AE forum at the Creative Cow.
Peder Norrby / Trapcode
Toccamonium_
on Dec 25, 2005 at 2:44:13 pm
Hi
If you want to have a snoweffect in Flash than get one of those
snowflake scripts for Flash (available in all kinds of Flash forums).
Because this is the only way to keep your filesize small.
http://www.hotel-saarschleife.de
Here you can see this effect in live.
But if you need a special fx right from Trapcode Particle then
would I recommend to export your animation as png sequence with the
alpha channel turned on. In the second step you can import the
image sequence into a movie clip. You just have to select the first
png file, the rest will be imported automatically. That's all you
have to do.
T.C.
