Lux lights showing behind a layer when it shouldn't
COW Forums : Trapcode
Dante Pignetti
on Dec 12, 2005 at 6:44:55 am
hello all
i got a rotating cube with vertical lights (using LUX) at the corners. The cube rotates slowly, showing each face.
it looks great except the lux lights appear through the face of the cube when the shouldn't
For example, if face 2 is facing the camera, then face 4 should be invisible, bec. it's the furthest-most face farthest from the camera. however the lights are appearing in face 2
here's a screen shot...
http://www.red-army.net/imx/lights.jpg
help?
Peder Norrby
Re: Lux lights showing behind a layer when it shouldn't
on Dec 16, 2005 at 4:32:56 pm
I'm afraid Lux is not smart enough to know that the light is actually behind that layer. You can use two instances of Lux and have one render the lights in front and one that does the lights behind. You'd need to name the lights "Front"... and "Back"... and use the General>Name starts with "Front" and "Back" on the two instances. Of course if one light moves from the back to the front this approach won't work. In that case the lights need to be switched on or off at time of obscuration or appearance.
Currently, there is no way for an AE plug-in to know about all other layers in the comp, it's just not in the API.
Peder Norrby / Trapcode
