Particular obscured by mutiple layers?
COW Forums : Trapcode
theGentleman
on Nov 9, 2005 at 6:40:23 pm
Is it possible to obscure a particular effect with multiple objects? - the interface only allows you to select 1 layer. I have also tried to place all the objects within a nested comp, but that doesnt work.....
Any ideas would be greatfully received,
Many thanks
Nick.
Peder Norrby
Re: Particular obscured by mutiple layers?
on Nov 10, 2005 at 12:15:00 am
Well there is a little trick that allows up to three layers:
Set Visibility>Also Obscure With to All
Temporarily set Physics>Model to Bounce
Select the Physics>Bounce>Floor to a second obscuration layer
Select the Physics>Bounce>Wall to a third obscuration layer
Now set back Physics>Model to Air
Now all three layers will obscure the particles.
Peder Norrby / Trapcode
theGentleman
on Nov 10, 2005 at 9:16:02 am
Will try it now!
Many thanks Peder.
Kevin Dooley
on Sep 19, 2007 at 6:42:54 pm
That worked perfectly for something I was working on (except I actually need to obscure 5 layers)... is there any chance the next version of particular would allow multiple obscurations, or is there some limiting factor in the coding? I ask because I assumed from your sig that you work for Trapcode... if I'm wrong, I apologize, but would love to hear anyone's musings on the subject.
Kevin Dooley
Senior Content Creator
Lake Pointe Church
