Unexplained Transparency in Particular Project
COW Forums : Trapcode
Kierra
on Nov 8, 2005 at 6:42:42 pm
I am working with Particular and some of my particles are showing up semi-transparent. However I have the Opacity set to 100% with 0% Randomness and with the Opacity staying constant over life. I also changed the visibility settings so that the Far/Near Vanish points and start fade points are the same. So why are some of my particles semi-transparent? Is there a setting I'm missing? Thanks!
Kierra
Peder Norrby
Re: Unexplained Transparency in Particular Project
on Nov 8, 2005 at 7:00:09 pm
Maybe you have Motion Blur on?
Peder Norrby / Trapcode
Kierra
on Nov 8, 2005 at 7:07:44 pm
Nope. Is there a way I can attach a screengrab of my settings?
I am using the layer emitter. Does it steal Transparency from the layer? I told it not to take any settings from the layer....
Peder Norrby
on Nov 8, 2005 at 7:14:04 pm
Yes, it always uses the alpha channel.
Kierra
on Nov 8, 2005 at 7:29:00 pm
that explains it! thanks!
Kozo Okumura
on Apr 24, 2011 at 9:53:04 pm
I have the exact problem and you seem to find the solution but I don't get it.
Could you kindly tell me how you fixed the problem?
thanks
Kierra Parlagreco
on Apr 25, 2011 at 5:00:41 pm
It was a loooong time ago. But I think what happened was I had a layer emitter that had a feathered edge and so all the particles being emitted from the feathered edge were semi transparent.
I can't remember for sure though. But check that.
Kierra Parlagreco
Filmworks, Inc. NY, NY
