echospace and Invigorator
COW Forums : Trapcode
Philip Rachford
on Oct 26, 2005 at 4:25:38 pm
Is there a way to use the z space functions if echospace is applied to Zaxwerks Invigorator?
Invig's layer needs to be 2d.
Phil Rachford
biggie
Re: echospace and Invigorator
on Oct 26, 2005 at 11:05:35 pm
yup....but only for up to 8 echospace layers. You don't want to put echospace on the invigorator layer, but rather another solid layer that you'll later turn the visibility off for. Just set the "Sets" in invigorator to follow some of the layers created by echospace. Then set your 3D objects in invigorator to follow the corresponding sets. By turning off the visibility of your echospace layers you should have 3D objects that track the solids echospace created. Let us know how it works out.
