Particular tornado?
COW Forums : Trapcode
Casanunda
Particular tornado?
on Oct 21, 2005 at 11:49:46 am
Hi there
I've been trying to make a tornado with Particular but i can't seem to get it to spin around it's axis - i'm fairly new to all this and i'm not even sure it's the right plugin to use - it just looked like somthing that could solve my problems. So i turn to the experts - is there a setting that i've so far not found that will make my colum of particles rotate in a tornado like fashion?
Cas
Mylenium
Re: Particular tornado?
on Oct 21, 2005 at 5:27:51 pm
No, not really. The only emitter types that really rotate are box and layers, but even then it does not look real. If you can, try to use other tools - it's simpler and will render faster. It's not impossible to create a funnel with Particular, though. The key to success is to keyframe the emitter position to form a crossection of the funnel and then play with Air resistance, Spin and Turbulence to deform it and make particles move.
Mylenium
[Pour Myl
