shine update
COW Forums : Trapcode
authentic
shine update
on Oct 20, 2005 at 9:32:43 am
I was testing shine (trial version) for a possible use in digital fusion as the afterfx plugins works in digital.
The plugins is really cool, I like itbut if it works on df 4, it has probleme on df5. The plugin is loaded and you have the parameters but if you want to show the result, it bugs and the soft close....
Is there an update/modifcation soon to resolve this problem ??
Mylenium
Re: shine update
on Oct 20, 2005 at 9:49:47 am
I wouldn' say it's impossible, but since they changed the entire plugin architecture for DF, questions regarding the compatibility of the AE host should be directed to them first. It's definitely not the fault of the plugin, as it runs fine in AE (which it is originally intended for) - the DF plugin host just does not provide the proper environment for it to work.
Mylenium
[Pour Myl
