Particular- custom particle fade in/out
COW Forums : Trapcode
Mark O'Connell
on Oct 18, 2005 at 12:22:18 am
Using Particular with a pict as custom particle, I don't seem to be able to get a smooth fade up/down for the particle. I've made a nice smooth curve on the Opacity Over Life graph but still have some particles "popping" in and out. Any suggestions appreciated.
Peder Norrby
Re: Particular- custom particle fade in/out
on Oct 19, 2005 at 6:25:02 pm
There are so many things that could cause this, the easiest is if you can send me the project file and the pict and I'll have a look.
send to: peder (at) trapcode.com
Peder Norrby / Trapcode
Mark O'Connell
on Oct 19, 2005 at 10:06:35 pm
Peder
Thanks for your response. In playing around with this I'm beginning to suspect that the problem has something to do with the
particle size paramater that I'm using. When the size is scaled up to 100 or 150 There will be popping, when it's lower, say below 25, things look smoother. I haven't used particular long enough to know if that would make sense in terms of how it handles the files. If I'm unable to resolve this I will take you up on your offer and send you the project and pict.
