Particular spline animation control
COW Forums : Trapcode
Scozza
on Oct 12, 2005 at 5:10:45 am
Hey Guys,
Just wondering if there's any way to conform/attract particles to a path? I want the particles to drift but still be loosely constrained to a path shape.
Any Ideas???
Mylenium
Re: Particular spline animation control
on Oct 12, 2005 at 11:31:51 am
Not really. there are no built-in constraints/ guides. You could try to use Air Resistance and balance it with your Velocity and Velocity from Motion... This is a bit tricky to set up and obviously particles won't move any more after a while, but it's as good as it gets.
Mylenium
[Pour Myl
Peder Norrby
on Oct 13, 2005 at 8:20:00 am
You cannot emit from a path or make them flow in a path, but you can always animate the emitter in a certain path - "draw a shape" with the emitter Position X&Y. I'm not sure but it sounds like that is what you may need.
Peder Norrby / Trapcode
