Recreating HYPA animation
COW Forums : Trapcode
lasvideo
on Oct 2, 2005 at 12:21:27 pm
Peder, heres a question about 3D stroke. I have recreated the HYPA animation but there seems to be a problem I cant figure out. If I use "bend at center" I get a smooth rotation on the y axis as the logo goes from curved to flat, but the last 5 frames it moves toward the camera (both internal and AE), then moves offscreen then pops back into place. If I dont use "bend at center" the logo wobbles as it rotates and trying to compenstate by tracking it with the camera is not satisfactory. I know this move is possible as seen in the HYPA piece. Any suggestions?
Peder Norrby
Re: Recreating HYPA animation
on Oct 4, 2005 at 11:38:24 am
Don't use bend around center, unstead change Order to "Translate, Rotate" then you can control the rotation center using the Z Position slider. To recreate the HYPA animation you'd need to keyframe Bend, Z Position and Y Rotation.
Peder Norrby / Trapcode
lasvideo
on Oct 4, 2005 at 1:48:19 pm
Thank you very much Peder.
