Problem with particular
COW Forums : Trapcode
td
by
on Oct 2, 2005 at 4:42:32 am
I had two layers with particular on them in this project. Later, I noticed after creating them that there was a new spot light created too.
Later, I pre-comp'd a group of layers with these two and the light. But somewhat afterwards I noticed that 1 particle layer was no longer visible. (I mention the light thinking this possibly has something to do with it?) Yet the other layer is visible.
If I reset the effect, it is visible but I have lost all my settings and key-frames. What is making this effect visible-invisible? Did something get lost when I pre-comp'd?
thanks,
Td
td
Re: Problem with particular
by
on Oct 2, 2005 at 4:58:14 am
As usual. I solved the problem shortly after posting. doh!
I tried resetting everything and when I went to change the emitter source layer, it complained that the source layer was not 3-D, so recreating that link fixed the problem.
thanks cow,
td
