Trapcode split clips
COW Forums : Trapcode
paule
on Sep 27, 2005 at 10:46:26 am
Hello, Thanks very much for the last advice on partuicular!
Another question... in trapcode particular in the time sampling I looped clips of people clapping. They are clapping at the same time in the individual clips but in the crowd of particles they don't seem to loop at the same time. If you can help me it would be great Thanks.
Peder Norrby
Re: Trapcode split clips
on Sep 27, 2005 at 11:16:10 am
Sorry, I don't understand the question.
Peder Norrby / Trapcode
paule
on Sep 27, 2005 at 11:33:15 am
Hello, sorry I didn't explain very well. In trapcode particular In the custom and time sampling section in the particle sub menu I selected split clip -loop- from the drop down menu, the custom layer it refers to is a pre-comp which has 8 animated clips of 8 different people clapping their hands. They are clapping at the same time on each clip but the loop the particules are making seems to be random and individuals are not clapping at the same time. Basicly I want a crowd of people all clapping at the same time to a music track using split clips.
Peder Norrby
on Sep 27, 2005 at 11:38:40 am
Oh, I see. Hmm... The time the clap happens is controlled by the time the particle is born so basically you want all to be born at the same frame.
Just keyframe Particles/sec starting at at high value at the first frame and then zero at the next frame and they should all get the same timing.
I *think* that should do it, please let us know how it worked out!
paule
on Sep 27, 2005 at 11:50:19 am
I already keyframed the particle from a high number to '0'on the next frame so that particles don't appear but the moment the clips loop still seems to be random.
Peder Norrby
on Sep 27, 2005 at 12:07:12 pm
I just tested it here and it works fine.
Peder Norrby
AE project for you
on Sep 27, 2005 at 12:17:49 pm
http://www.trapcode.com/etc/clapper.aep
ctrl-click and select "save as"..
Peder Norrby
Re: AE project for you
on Sep 27, 2005 at 12:18:52 pm
paule
on Sep 27, 2005 at 12:23:09 pm
Hello, sorry I didn't keyframe it on the first frame of my layer, it's now working. Thanks ever so much! you are great.
