Source Opacity trouble
COW Forums : Trapcode
ssvideo
on Aug 2, 2005 at 12:46:46 am
After applying the shine effect, the source opacity is greyed out and cannot be adjusted. In a previous thread I learned that it depends on the transfer mode selected... How do I change this mode to allow adjustment of the source opacity. Sorry for the rookie question, but hey, I'm just a rookie.
Mylenium
Re: Source Opacity trouble
on Aug 2, 2005 at 6:07:51 am
Erm, look at the magic buttons near the source opacity... ;o)
Mylenium
[Pour Myl
ssvideo
on Aug 2, 2005 at 5:39:11 pm
I have pressed every button in the area, and the source opacity is still "greyed out" which will not allow me to change the settings. Maybe i am just not seeing what I should???
Peder Norrby
on Aug 2, 2005 at 9:13:09 pm
what host are you using?
normally just select any other Transfer Mode than "None" and it should be ungreyed.
Premiere Pro is a little buggy on this sometimes - if so try disable/enable the effect and see if that helps-.
Peder Norrby / Trapcode
