trapcode particular clip split is repeating itself
COW Forums : Trapcode
thisisthepope
on Jul 27, 2005 at 11:25:37 am
Hullo all. I'm trying to emit a constant stream of different particles and have been using a custom layer set to split loop where the layer is a sequence of 100 different layers playing for 4 seconds each. However the problem is that particular seems to play the clips in random order and many times repeating itself. Is there any way to stop it repeating itself?
Mylenium
Re: trapcode particular clip split is repeating itself
on Jul 27, 2005 at 5:54:17 pm
No, not really. You would have to re-seed the random values used for picking clips nad there is no option to do that within animation. The only solution to this for the time being is a) making your clips longer and built some randomness into them or b) use multiple layers of particular referencing different custom particles. Neither yields perfect results, though.
Mylenium
[Pour Myl
