3D Emitter Path for Particular
COW Forums : Trapcode
Kierra
on Jul 15, 2005 at 4:34:48 am
I'm trying to have my little particle field travel through 3D space ocassionally stopping to circle around an object. Sort of like the Winterfresh spot in the galleray. Is there a simple way to draw a path for this or do I have to just create a series of key frames. I can't figure out how to draw a 3d motion path especially since the emitter axis are split up.
Please advise. Thanks.
Mylenium
Re: 3D Emitter Path for Particular
on Jul 15, 2005 at 5:18:55 am
Try using a dummy Null layer or solid and then pickwhip the emitter position to this solid's position parameters. This will give you a maximum level of control and visual feedback.
Mylenium
[Pour Myl
kierra
on Jul 15, 2005 at 1:24:55 pm
Thanks. That's what I was going to try to do today. So now you have given me additional confidence!
Kierra
