Ribbons Falling From The Sky?
COW Forums : Trapcode
kozi_kozi_kozi
on Jun 15, 2005 at 7:54:55 am
Is there any way i can animate ribbons falling from the sky using Particular? I desperately need help.
CMedia
Re: Ribbons Falling From The Sky?
on Jun 16, 2005 at 10:04:52 am
Not sure what type of animating you are trying to achieve (postion, color, etc.), but you could place your ribbon layer into a pre-comp (animate it within the comp if you need to do it there) and then make that precomp your custom particle type.
kozi_kozi_kozi
on Jun 16, 2005 at 10:51:39 am
Sorry, ive got no idea what you said, im an after effects newbie (anything else i can use, i just cant get my head around it!)
can you explain it to me in english. Waht i want to achieve is to animate red ribbons falling from the top of the image and slowly fall to the floor.
CMedia
on Jun 16, 2005 at 7:51:21 pm
First question I guess, is do you have Trapcide Particular?
kozi_kozi_kozi
on Jun 17, 2005 at 4:08:21 am
yes
CMedia
on Jun 17, 2005 at 8:23:01 am
Ok this is pretty easy.
Make your ribbon in photoshop, or whatever making sure it's no bigger than 100x100 pixels.
Drop that layer into your comp.
Turn that layer's visibity off.
Make a new layer above it at same size as comp.
Add particular to this new layer.
Twirl open Particle and change default sphere to custom.
Make custom layer from none to your above "invisible layer".
Your done!
This is available in the help stuff too.
Shows examples. Click options and then help at the bottom of the window.
