Soundkeys - moving along to the beat
COW Forums : Trapcode
TallShaw
on May 17, 2005 at 6:28:15 pm
I have an object that I want to move along the X position, the movement coinciding with a bass beat. Unfortunetly I can only get soundkeys to move in between the min max values. How can I enable soundkeys to remember my current X position and then incremently move along the X whenever a bass beat hits. Is this possible ?
Thanks in advance.
andrew shaw
senior interactive designer
OgilvyInteractive
Cape Town
t +27 21 4671114
m 082 3363707
e andrew@oi.co.za
Peder Norrby
Re: Soundkeys - moving along to the beat
on May 19, 2005 at 12:47:20 pm
Change the Fallof mode to "None (Integrate)".
See this example:
http://www.trapcode.com/info_falloff_none.html
Peder Norrby / Trapcode
TallShaw
on May 19, 2005 at 1:49:25 pm
Awesome, thanks Peter.
On a side note, this works great in a 2D environment but as soon as you move to 3D it does'nt work out so well. Because you can't control X Y Z independently, your object placement goes haywire. I did, however find a solution on AE Enhancers though that allows you to control all three positional properties seperately by way of utilising slider controls and a small but of code. And it proved to be a life saver.
The link for others in the same boat as I was in.
http://www.aenhancers.com/viewtopic.php?t=53&sid=864ed3a99b6e5207124ff5d6cf...
