text following curves made with 3dstroke
COW Forums : Trapcode
J
by
on May 13, 2005 at 7:50:20 am
Hi to all, I
Nick Berrisford
Re: text following curves made with 3dstroke
on May 14, 2005 at 5:19:31 pm
You ccould draw a path that follows the contour of the lines you want it to follow as ooposed to trying to use the same path that you used for 3Dstroke. That's probably the most immediately effective solution.
Nick Berrisford
on May 14, 2005 at 11:42:22 pm
I see what you are trying to do. While my first solution would make it follow the lines, you won't get the distortion. Not sure there's a way to get the text ti bend on a pth in a true 3D space . . . however, you could fake it by using individual letters and rotating them in as 3D layers.
fausto pacheco
on May 17, 2005 at 10:46:49 am
thsnks for the help, but for a big amount of texto that will be an herculian job, I think.
thanks
