Rotation Shine's Light Rays Using Phase within Shimmer...
COW Forums : Trapcode
Kirk Wilson
on May 11, 2005 at 4:07:55 pm
Is this how you do it? In terms of rotation, I am not having any success animating my light rays. I keyframe two points and set the degrees from 0 to 180. After previewing, nothing. Also, I set up the loop the same way, nothing.
Kirk Wilson
(225) 473-8874 ext:210
Kirk Wilson
Re: Rotating Shine's Light Rays Using Phase within Shimmer...
on May 11, 2005 at 4:22:10 pm
sp: rotating
Kirk Wilson
Peder Norrby
on May 11, 2005 at 7:48:46 pm
Shimmer does not rotate the rays.
Use the layer's Rotation property to rotate.
Or rotate the input to Shine.
Peder Norrby / Trapcode
Kirk Wilson
on May 11, 2005 at 8:03:26 pm
I would prefer not to rotate the actual layer, so how to you rotate the input?
Kirk Wilson
Kirk Wilson
on May 11, 2005 at 8:31:54 pm
If I duplicate the layer and change the copied layer's opacity to 0, rotate it, then I should have a rotation. Is this the hard way?
Kirk Wilson
Kirk Wilson
on May 11, 2005 at 9:20:43 pm
Rotating a copy doesn't do well since the images reflections do not match the image. So how do I rotate the input to Shine. This sounds like something very easy, but at the time, I think I may be overlooking something.
Kirk Wilson
Mylenium
on May 12, 2005 at 8:23:27 am
Huh? You have to rotate your image but use Shine on an adjustment layer above it. Do this in a separate comp if you don't want other layers to be affected by Shine. Shine itself offers opacity controls and blend modes so use them for more refinement. BTW, the Rotation parameter for the Shimmer is simply a input parameter to the formula that will vary the noise that creates the shimmer effect (just in case you wanted to know). I think the noise is based on simple sinus/ cosinus operations (Perlin?) in which case it would be technically correct to name the parameter "Rotation" but it's quite confusing on the user end. Maybe a candidate for a rename, Peder?
Mylenium
[Pour Myl
Peder Norrby
on May 12, 2005 at 11:51:18 am
[Mylenium] "it would be technically correct to name the parameter "Rotation" but it's quite confusing on the user end. Maybe a candidate for a rename, Peder?"
Actually, the parameter is not called "Rotation" - it is called "Phase"!
And yes, it is perlin noise so I think "Phase" is quite appropriate, it is the current phase of the noise.
Peder
Mylenium
on May 12, 2005 at 5:57:06 pm
Ah, didn't check, just reffering to the other post. But thanx for the clarification anyways. (kinda funny how one even confuses parameter names on a tool used 3 times a week *giggle*)
Mylenium
[Pour Myl
