How can I Move Spline Editpoints in selected polygon Normal direction?
COW Forums : Autodesk Maya
Mohammad Taha
on Apr 5, 2017 at 9:31:37 am
Hi Everyone,
I am Working on a script for a automatic cleaning of scenes.
The scenes are a mix of Polygon and Spline.
For examble I have a modling of a Hat with one spline going along the surface.
Problem case : the spline is crosing the polygon.
Answare: scale the spline a little bit so it stays outside the modling.
secound Problem: scale tool does not always work, for examble organic shapes with a spline what moves in X-, Y- and Z Direction.
My Idea: Select all edit points of the Spline and move them X-units into the direction of the nearest Polygon Normal of selected Object.
Unfortunately I didn't find a way to do so. Even with mel or Python scripting.
Thx for help and I hope we get a solution :-)
Mohammad Taha
Re: How can I Move Spline Editpoints in selected polygon Normal direction?
on Apr 12, 2017 at 6:28:02 am
Just for intrest.
I have solved it and made a small MEL script for that.
If there is intresst just contact me.
cheers.
This can be closed
