Mash Trails Flickering
COW Forums : Autodesk Maya
Gabriel Mangiru
on Feb 4, 2017 at 4:29:00 pm
Hello. I started to use mash recently and I found this annoying problem. If I add the MASH_Trails node , connect by distance, no matter what settings I use the trails flicker. At first I thought it's because of the Signal node, so i have removed it. But they still flicker.
It seems that the trails don't move along with the cubes. However they work fine in any other mode apart from Connect By Distance. Any solutions? Thank you.
Eric Santiago
Re: Mash Trails Flickering
on Feb 7, 2017 at 1:11:28 pm
I have no experience with Mash Trails.
However, how does it look after render?
The flicker reminds me of redraw issues with the card.
Gabriel Mangiru
on Feb 9, 2017 at 2:39:17 pm
The flicker is present in render files as well. It would not have been such a problem if it was just the viewport.
