render only visible part of an object Arnold Maya 2017
COW Forums : Autodesk Maya
look dev
on Jan 13, 2017 at 5:27:32 pm
imagine a fountain, there is the fountain body, and water coming out and flowing down.
I have water mesh in RealFlow, imported in Maya
Assuming I have to render the fountain in E-on vue and the water in Maya2017 (Arnold),
What shader should I apply to the fountain in Maya so when I render the water alone, I only see the visible parts of water in the scene, and not the whole mesh I got from realflow?
I tried "background shader" to the fountain, didn't work.
What shader do I have to apply to the fountain to block the water mesh part th fountain is supposed to hide in the render?
Thank you
