Texture Reference Object Not Working
COW Forums : Autodesk Maya
Jennifer Adams
on Oct 27, 2016 at 9:32:41 am
I'm using Maya 2016 and can't seem to get rid of texture swimming with the Texture Reference Object.
After applying a 3D texture to a polygon object, when I go to Texturing > Create Texture Reference Object, it is indeed created, but the texture still swims when the object moves.
I'd appreciate any help!
Thank you.
Eric Santiago
Re: Texture Reference Object Not Working
on Oct 27, 2016 at 2:34:37 pm
Send the file lets see.
Jennifer Adams
on Oct 31, 2016 at 8:07:14 am
Here it is:
10749_texturereferenceproblem.ma.zip
Jennifer Adams
on Nov 12, 2016 at 11:16:29 am
Help anyone? I'm still trying to figure this out with no luck...
Eric Santiago
on Nov 14, 2016 at 2:27:24 pm
[Jennifer Adams] "Help anyone? I'm still trying to figure this out with no luck...
Sorry I just saw your post now.
Ill give this a go today.
Eric Santiago
on Nov 14, 2016 at 3:01:49 pm
I dont have 2016 but tested in 2014.
Moving the polySphere around I dont see the issue.
Doing transform animation test render now.
Eric Santiago
on Nov 15, 2016 at 2:02:14 pm
Did a simple animation and found no issues.
Here is a sample
Jennifer Adams
on Nov 18, 2016 at 11:14:57 am
Thanks a lot for your help, Eric!
I just read somewhere that this is a bug in Viewport 2.0 in Maya 2016 and above, but batch renders do work OK.
I appreciate it :)
