Lambert Problem
COW Forums : Autodesk Maya
sean peters
Lambert Problem
on Oct 25, 2016 at 1:41:12 pm
I recently started learning Maya. I have installed Maya 2017 student version.
The problem is,
1) I add a nurbs or polygon plane
2) Then I add a Lambert
3) When I click the black, white square thing right side of the color nothing happens. (I want to add a reference image)
Please help me to solve this problem,
Thank you
Eric Santiago
Re: Lambert Problem
on Oct 26, 2016 at 12:56:38 pm
You will need to learn more on texturing.
The checker icon is for selecting a Render Node (Texture Node).
Basically, a sub-node that helps achieve the look you are going for.
Choose any Texture and you should see the results if you've applied the Lambert (choose a Phong for better results).
© 2018 All Rights Reserved
