Fluids interaction with SideFX Houdini
COW Forums : Autodesk Maya
Simone Sammartino
on Jun 26, 2016 at 6:37:58 pm
Dear all.
First of all, sorry if I put my post here, but I did not find a specific SideFX Houdini forum section.
I have a project about two fluids with different densities interacting each other.
A good starting point for a more complex dynamics would be a tank filled with a fluid with a certain density and another different density fluid pouring from a certain object into the tank. I can make it, I can set a different density for the two fluids, but the pouring fluid is not colliding with the tank.
Any solution?
Thank you in advance.
