Create seamless joins on a blocky character rig?
COW Forums : Autodesk Maya
Cameron Bell
on May 1, 2016 at 3:24:53 am
Hi this is my first post, so I apologise for any errors.
I am in the process of rigging a character. It is a stylised character that looks kinda like a minecraft character. For each body part (arms, legs, body ect) I have create joints, made an IK handle and then skinned them to their appropriate body part. and this works great! But the points where the leg/arm meets the body does not look clean at all, because they are separate meshes. Here is a picture of the problem:
I realize that it is not clear exactly what I would like. So here is a picture (The angle is not very good so I apologise)
I thought that the obvious way to fix this, would be to make the arms and body just one mesh. But when I then skin the mesh, moving the arm takes the body with it. So then when I tried using the paint blend weights tool and flooded the body with black, the body disappeared! So I have know I idea how to fix this.
--Thank-you in advance
Eric Santiago
Re: Create seamless joins on a blocky character rig?
on May 2, 2016 at 5:22:49 pm
You have to create that as one polyset.
You have to polysets that dont match at the joint.
Cant expect the IK to make that smooth.
