How do i smooth these rough edges?
COW Forums : Autodesk Maya
Faline Farwell
on Feb 25, 2016 at 9:20:34 pm
I'm working on a model and after using various extrudes, vertex merges, booleans, etc. I have noticed these pesky edges on my model that I can see in the render. How do I smooth these out so the surface is smooth and the edges do not appear in the glare. I am new to modeling so please give me specific tips if you can :) thanks for any help!
It's only a few of the edges that are rough sharp and noticeable.
Here is an image of how my edges and verts are setup.
Here are the rough edges you can see in the glare.
Eric Santiago
Re: How do i smooth these rough edges?
on Feb 26, 2016 at 4:18:22 pm
Have you tried rendering this to mr/rman and see what the results are?
The Maya UI tends to show oddities with normals on both NURBS/Poly at times.
You can try to up the polycount but not sure if you want that burden.
