Maya, Image Sequence (Image Plane, Camera) BLACK when "Use Image Sequence" enabled
COW Forums : Autodesk Maya
Thomas Brecheisen
on Feb 16, 2016 at 5:06:06 am
I've done this a million times, but I just ran into this issue for the first time.
I have an Image Sequence: 8plate.0345.png - 8plate.0406.png loaded into the Image Name of the imageShapePlane1 node, but when I select "Use Image Sequence" the image on the plane goes BLACK.
I tried renaming, saving as jpg, and restarting Maya. Same result. Any help out there?
Thanks in advance. (If I'm missing any key info, please let me know, I figured this was enough, but I might be wrong. Thanks)
Thomas Brecheisen
Re: Maya, Image Sequence (Image Plane, Camera) BLACK when "Use Image Sequence" enabled
on Feb 16, 2016 at 7:41:01 am
Disregard. Solved! Rookie Mistake.
I realized I had to OFFSET the frame to 0345. (Duh, right?!)
