Image plane keeps moving to the side
COW Forums : Autodesk Maya
Nathan Stobbs
on Nov 29, 2015 at 2:41:59 pm
I have this image plane that I created with a tracked camera, but when I add the footage the image plane will move to the side after 3 frames, but when I set the display to "in all views" then "looking through camera" than back to "in all views" the footage goes back to the right spot then moves again.
Larry Turner
Re: Image plane keeps moving to the side
on May 9, 2016 at 8:44:02 am
I am having the same issue with a Matchmover track. Were you able to find a solution?
Nathan Stobbs
on May 9, 2016 at 4:02:09 pm
I had to reinstall Maya and install the service packs
Here is the links for the service packs,
https://knowledge.autodesk.com/support/maya/downloads/caas/downloads/conten...
