about animation
COW Forums : Autodesk Maya
Jefferson Andres
about animation
on Sep 10, 2015 at 1:47:40 am
hi guys im here again asking for your help, I'm still new in Maya and while I'm rotating my skeletons suddenly my main model became small and I cant even rescale or move it, I cant redo it also so I'm stock on it. any suggestions?
thank you again in advance
Eric Santiago
Re: about animation
on Sep 15, 2015 at 12:40:44 pm
It has removed itself from the BIND.
Did you create the model in the center (zero coordinates)?
Then create the IK at same spot?
There are tons of tutorials that explain to always create at zero position to avoid mishaps like this.
Not so sure how your mesh got moved away, can you send me the file so I can see it myself?
© 2018 All Rights Reserved
