hi Maya prof.
COW Forums : Autodesk Maya
Jefferson Andres
hi Maya prof.
on Aug 23, 2015 at 5:49:48 pm
I'm just new in maya and I'm having a problem regarding this duplicate special.. how to release this black thing from duplicate special once i'm done using it. coz I can't combine the 2 objects.
Eric Santiago
Re: hi Maya prof.
on Aug 31, 2015 at 3:42:19 pm
Go into Hypergraph and select offending node and delete.
Unless of course you destroyed History.
Seung Yoon
Re: hi Maya prof.
on Sep 3, 2015 at 6:05:43 pm
this happened because your normal is flipped.
your scale is -1 in the x direction.
to fix this
1. left click on you dark object
2. Right click on your object
3. Click face
4. Double click on any of the face to select the object
5. switch over to the POLYGON Menu Set
6. In the top menu click on Normal and click reverse and it should fix that
there is a 'fake' fix to it which I don't recommend, because it may cause rendering issues is to turn on double sided lighting.
1. click on the Lighting on the shelf menu and click two sided lighting.
cheers
Seung Yoon
Jack Gall
Re: hi Maya prof.
on Sep 8, 2015 at 6:38:51 pm
I'm not on my computer so can't remember exactly but if you go edit uvs and flip it will make the outside grey and the inside black, Maya just gets confused at what is the outside and inside :)
Joel Stutz
Re: hi Maya prof.
on May 24, 2016 at 11:29:02 pm
first click on "Modify> Freeze Transformations" in order to zero out the transforms and having the mesh looking grey again. Then click on "Mesh> Combine" to combine them, only now you can merge the vertices, go to "Edit Mesh> Merge Components". Hope it helps, regards, Joel Stutz
